Think my battery is done-14 sgs
Old 09-22-2018 | 09:11 PM
markwolula's Avatar
markwolula
Some do ,, some don't,,, But,,, (if you have a battery tenderer , not a battery charger), I would connect new battery overnight, to get it up to full charge before first crank/start.....
Also before disconnecting old battery, there is a procedure before pulling maxi fuse, (if you have security system)…..
1. Pull side cover where maxi fuse located.
2. With fob present,,,, Turn ignition ON , (let security system disarm).
3. Turn ignition OFF ..
4. Pull maxi fuse.... (you have approx 4 - 5 seconds before the security system will arm again)…..
5. Remove old and replace with new battery ….
6. Install maxi fuse ,, and start as normal …..
The following 2 users liked this post by markwolula:
mctraveler (09-23-2018), Sierra977 (09-23-2018)
Old 09-22-2018 | 09:45 PM
RichM752's Avatar
RichM752
Old 09-22-2018 | 10:06 PM
bikerlaw's Avatar
bikerlaw
What kind of tender, if any, do you use?
I destroyed my battery in no time with an older tender. The new batteries require the new style tenders.
Old 09-23-2018 | 06:49 AM
hemi1300's Avatar
hemi1300
thank you for this heads up. Didn't even think about the security system before I pull the battery
Old 09-23-2018 | 06:51 AM
hemi1300's Avatar
hemi1300
https://www.amazon.com/Battery-Tender-SuperSmart-Constantly-Encapsulated/dp/B000CITKCE
this is the battery tender I use
Old 09-23-2018 | 06:53 AM
hemi1300's Avatar
hemi1300
Old 09-23-2018 | 07:00 AM
Cozz's Avatar
Cozz
Super Crank from batterymart.com. 109.95 shipped as of last week, when I got mine. Ordered on tues. had it on thurs. bike starts instantly now.
Old 09-23-2018 | 07:07 AM
Andy from Sandy's Avatar
Andy from Sandy
That battery tender 800 looks just like the HD one. I always hook my bike up after it has cooled down as I never know when I will ride it again.
I didn't ride the bike over last winter and it sat for maybe 2 months. Started up okay once the fuel system got fully primed.
Old 09-23-2018 | 07:43 AM
Cozz's Avatar
Cozz
Default Battery tender
what constitutes an “older” battery tender? Mine is about eight years old. It has worked fine on my last three agm batteries .
just curious.
Old 09-23-2018 | 07:59 AM
Andy from Sandy
I have a C-Tek battery tender charger that has a specific setting for AGM batteries. C-Tek mention that AGM requires a slightly higher charging voltage in cold weather.
I haven't used that setting for my car and it seems to work just fine. I don't know if the HD / Battery Tender 800 is specifically set for AGM or not.
Quick Reply: Think my battery is done-14 sgs
