2017 Street Glide Special, No crank everything powers up
Even tho the motor cranks over via the jumper, It wouldn't surprise me if the ECU won't start adding fuel / spark until it sees a start button message on the can. Fuel Pump prime says the BCM is good.
Add
Try tapping on the start switch.
Add
Max Headflow (09-15-2018)
Tried PIN same results, battery is 2 years old, this bike has give small problems with the security system ever since i had it, it will go off and still crank sometimes till now, when i installed the battery the alarm set off, had to disconnect it to stop the alarm, make no since.
doesn't help you this time, but in the future, if you have to disconnect your battery, before you do anything, disarm your security. then pull your maxi fuse. then you can start disconnecting your battery cables. especially important to do this if you have the optional siren installed, unless you like ear piercing noises....
