Cant get LED turn signals to work properly even with custom dynamics stabalizer
I installed the lights in the front and rear but one side is dimmer and one turn signal wont work. I have the custom dynamics stabilizer installed also but still isnt helping. Its a 2010 street glide. My LED lights are from Eagle light.com
Hi Travis,
We're open for another 10 minutes, and then again at 8:30 AM EST tomorrow morning. If you want to give us a call, we can troubleshoot and help figure out what's causing the issue.
__________________
Custom Dynamics® - EVERYTHING To Light Up Your Ride!®
15 Cypress Drive
Youngsville, NC 27596
sales@customdynamics.com
https://www.customdynamics.com
http://blog.customdynamics.com
Review Custom Dynamics
Phone: 800-382-1388
15 Cypress Drive
Phone: 800-382-1388
I will tell you this, I am so impressed with Custom Dynamics. I was recently troubleshooting an issue and thought maybe one of their stabilizers would solve my problem, called their tech guys at the suggestion of another friend. The CD tech couldn't have been more helpful and pointed me at the HD rear Run/Brake/Directionals module that comes as an after market OEM plugin logic module. Bingo.
Take advantage of the CD help.
Ok so I got everything working good now except my one rear turn signal light is very dull. The light will turn bright whenever I break or turn on the signal but the running light is dull. The light will flicker if move it around kinda like it has a short in the wires?? I contacted Eaglelight where I ordered them to see about getting a replacement. I even switched the bulb over to the other side and it did the same thing, so i believe this bulb is causing the problems
striper.seeker
2014-2023 Touring Models
13
06-17-2016 05:03 PM
