Squeaky brakes anyone?
At my first brake pad change I installed the EBCs. They squealed a little but not really bad. Their performance wasn't near as good as OEM and they didn't last as long either. So, until the aftermarket can produce a pad that can perform as well as OEM I'm going to stick with OEM. OEM is worth the price IMHO.
BTW... welcome to the forum!
I bought a new 2018 Street Glide and the rear brakes started to squeal very loudly at about 1500 miles. It was so loud it was embarrassing. I tried every fix I could think of. I applied disc brake quiet to the back side of the pads, beveled the edges of the pads with a file and sanded the face of the pads. Nothing worked. I replaced the OEM pads with EBC pads and so far they are completely quiet. The true test will be to see if they are still quiet after a couple thousand miles. Which type of EBC pads are you using? They have a few types, semi-sintered, organic, etc. Maybe try a different type. I would think a softer material would be less likely to squeal. Of course it would also wear faster and make more brake dust as well. If the semi-sintered pads I installed start to squeal I may look into getting the organic pads. I’m no expert on brakes, just sharing my experience with what I did.
Back when the touring bikes first got the brembo brakes, there was an issue with the rear brake squealing. If i remember correctly, the MOCO suggested applying copper grease on the back of the rear brake pads. they even gave you a little stencil and grease to apply the grease in the correct pattern when you bought a rear brake pads. I'm not sure if they still provide the stencil and grease in the brake pad box but it is super easy to do. This worked for me on my 08' 10' + '12 models.
My new to me 15 flhp has a tendency to squeal at lower speeds so I'm probably going to do this myself.
Hello guys....ASE Certified Auto Tech with 30+ years experience here. I own 2 Harley’s...A 2012 Ultra Limited and a 2015 Road Glide. Bought both new and after a few months they both suffered from brake squeal. What we use on all brake jobs is a product from Permatex called Extreme Ceramic Brake Lube. The secret to solving brake squeal is stopping the pads from vibrating. Just a little of this lube is all you need. Remove the pads and clean all contact points where the pads touch the caliper and pistons as well as the anchor pins. Apply a thin layer of the lubricant to each of the pistons, the caliper lands that the pads rest on as well as the pins that go through the pads. When finished, you won’t hear a peep from the brakes. I hope this helps.
Ricochet59 (01-04-2019)
