volts light burned out
Hello!
The gauge light in my volts gauge is burned out.
Harley wants 16 bucks plus for four, I'd rather just get one to fix it.
I read somewhere about Sylvania 185, but that it is a bright white light and doesn't match.
Any ideas on the cheapest way to fix the light?
Thanks!
~Joe
Thanks!
~Joe
Are your asking how to change it or what to use? I’ve bought every replacement bulb I’ve used over the years for my 09 at the nearest auto parts. The only one that costed more than a dollar or two was the headlight. I’m pretty sure all you need is a common dash bulb.
To change it you will have to remove the outer fairing.
You could always replace all of your bulbs with LEDs and change the color as well.
https://www.superbrightleds.com/more...rofit-car/206/
Got to auto parts store and cross reference it and leave less than $2.00 on the counter.
One should be able to remove that yellow condom.
Rob
Ship your tack and speedo here and have the color changed to match. Now you have a very cool custom dash.
http://www.gaugemods.net/
Had mine done in all blue. Get lots of compliments on it.
