2018 streetglide special excessive brake dust
900 Miles on bike and rear brakes squeal when applying rear brakes, I tried compressed air to blow out rear caliper as per Harley service tech, rear rim covered in dust and extends on rear fender and rear of bags, my thought was lesser quality pads or much softer compound material is anyone else experience the same results
I use engine brake mostly, I use detail spray microfiber cloth wipe down quite offen with a wax spray too
Pads are semi metallic softer compound not uncommon for break dust was told like mentioned on this thread as they seat less dust, as far as squealing I do use down shift to slow down pads could be glazed might look into different pads next go around, did mention ceramic pads will squeal also
