Trying to run my SG cooler
RE: Trying to run my SG cooler
Not Really... Re-Mapping will still have you runnin' lean (HOT) as they (the dealers) still have to comform to EPA standards...
Need a Fuel Management System...
PCIII - FuelPak - ThunderMax... etc...
A proper set-up Stage 1 & Syn Oil (like Amsoil or Mobil 1) will HELP...
ORIGINAL: Bobberino
I have a 07 Street GLide and just have the Thunderheader. No air cleaner, no remap. runnin a air cleaner and remap of some sort will let my engine breath better and run not as hot, is that right?
There is no need to do the Stage 1 if you don't change the AC, but upgrading the AC will give you a meaningful boost in power. Doing that requires a remap of some sort, either Stage 1 or one of the above options.
And don't forget the oil cooler. Before i installed my cooler i had the stage 1 done using the fuelpak and the bike was still running in the 230 range. This was better than stock but not cool enough for me. After I added the cooler to the stage 1 it runs in the 210 to 215 range.
ORIGINAL: Softtail Bob
nashbk
05-11-2012 09:57 AM
