Changing cam cover gasket
Old 08-26-2018 | 01:57 AM
OZARKTOAD's Avatar
OZARKTOAD
Default Changing cam cover gasket
So oil leaking around can cover 2 years after cam upgrade. Can I get the cover off and replace that gasket without taking my header apart?
Old 08-26-2018 | 04:21 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
First things first. Are you CERTAIN it's the cam cover leaking and not oil from the air cleaner/cranks case vents? Second, if it is indeed the cam cover gasket it would depend on year, model of bike and the exhaust system.
Old 08-26-2018 | 09:43 AM
CndUltra95's Avatar
CndUltra95
Yup, make certain where the oil is coming form.
And one may get away with just loosening the header at the exhaust manifold and loosening the right side footboard/peg.
Dependent on the model and year of the ride.
You tube has lots of guys who post work arounds, some good some not so good and some really good.
Rob
Old 08-26-2018 | 12:13 PM
purpledeuce's Avatar
purpledeuce
If you’re running a stock header you should be able to remove the heat shield and get the cover off
Old 08-26-2018 | 05:48 PM
OZARKTOAD's Avatar
OZARKTOAD
It’s a 2012 103 roadking. I have Vance and Hines power duals on it. Also had a cam job done about 2 yrs ago. I’m about certain that oil is coming from the bottom edge of the cam cover. Took it on a trip to dallas (devils tit hot) and once parked down there it started pooling a little under the bike. So took it over to strokers mc and they tightened/sealed the plugs underside and said good to go.(awesome people there! Super fun place. Go there when in Dallas.). But it continued on my way back. I’m going to try to change the cam cover gasket but dread taking off that header!
jimmyjennings60@gmail.com
Shovelhead
06-27-2019 07:49 AM
bigsofty
05-14-2010 10:11 AM
Coastiejosh
12-03-2009 07:06 PM
deadman77
02-04-2009 06:59 PM
snotrocket18
Exhaust System Topics
01-10-2007 10:59 AM
Quick Reply: Changing cam cover gasket
