Pre '06 Tour Pak complete led conversion... $34!
I switched out the 1157 bulbs in my tour pak for red flashing led bulbs from Amazon.
I also replaced the side marker lights with red led strips from Amazon.
Before...
After...
During...
For $34, I am more than pleased.
Before...
After...
During...
They have a self adhesive backing. I wiped the tour pak surface down with an alcohol swab and just stuck it on there. The "After" picture IS with the lens reinstalled.
you only need a load equalizer for turn signals. leds have a much lower current draw than the incandescent bulbs so the ecm 'thinks' that you have a bulb blown and will flash fast to let you know. you can generally get away with changing either front or rear with led and no load equalizer, but not both. also, with the rushmore bikes and can-bus, a load equalizer is not necessary, so 2013 down.
The only modification I had to make to the lenses was to take a file and open up this middle section a little bit for the led strip to have room to fit underneath. The led strips can be cut to fit. I had to cut the last three leds off to make it the right length. Also, you can see in one of the pictures in the original post, I spliced the original wire connection onto the wires of the led strip.
