Cruise control roll off switch location
I also have an '09 ultra with cruise control... well, with all the bells & whistles. ![Icon Wink](https://www.hdforums.com/forum/images/smilies/icon_wink.gif)
I think the "switch" is integrated into the throttle position sensor (twist grip)... probably not anything to do with the throttle body. It sounds like you know how it works... just not sure why it's not working as you expect after messing with the turn signal buttons.
I've never had it apart... so, I won't be much help. Have you tried looking for an exploded diagram of the switch cluster and/or throttle control to see if the "ah-ha light" comes on?
Ride Safely!
John.
Ride Safely!
John.
I'm not sure what it takes to install those buttons, but check your clutch switch and brake switch behind the levers. If either is not properly working it can create issues with cruise.
The OP didn't explain the symptoms he's experiencing. So what exactly is happening with the cruise control?
I assumed cruise comtrol would activate as it should, but not deactivate when the throttle is rolled forward.
Ride Safely!
John.
