2002 Road King-Wiring Adapter for Tour Pak?
I have a 2002 Road King, that I installed Docking hardware, and swap between naked, a pillion/sissy bar, and a Tour Pak.
The tour pak didn't come with lights, and when its installed on the cycle, the brake light is semi-hidden under it...so I'd like to put a brake light on the back of the tour pak for better visibility to cages. Not as concerned about adding turn signals, but that's an option also.
Before I go cutting and splicing wires, does someone make a pigtail harness that taps into the existing harness by just unplugging a connector and tapping into the wiring I need without a lot of headaches?
