best replacement clutch cable? 2012 Ultra, do not want to lube if possible
What is the 'best' replacement clutch cable? one I do NOT have to lubricate if at all possible.
Standard black housing is what I want. Stock bike. Do not want braided cover etc....
Did forum search, not finding what I need.....
Unsure if newer HD cables need lubing or not, always read contradictions on that.
No issue w/ a new OEM cable if that's the best.
Thanks.
Thanks.
F150HD (08-14-2018)
I think Barnett or OEM would be fine. I wouldn't worry about lubing the cable as much as I would worry about lubing the ball end of the cable. If it breaks, that's likely the point where it will snap. Make sure your new cable ball end rotates easy in the socket. Put a little grease on it. Then the next time you do your PM and adjust your clutch, you can pull apart the cable lever, clean and inspect it, and hit it with a little fresh grease.
Harley's love that kind of treatment.
carl
carl
F150HD (08-14-2018)
FrankEV
02-08-2019 09:31 AM
F150HD
08-15-2018 04:53 PM
Iron lHorse
08-01-2017 12:08 PM
Talldog
07-23-2011 03:45 PM
