Left hand grip removal and re-Install
Old 08-14-2018 | 09:54 AM
Kingface's Avatar
Kingface
I had a left grip that was spinning. The previous person used Gorilla glue. I had to scrape it off using a utility knife but it worked fine. I put it back on using Gorilla glue, which may sound stupid since it didn't work the last time but Gorilla glue can be finicky as most people use it wrong. You need to WET the inside of the grip first with water.......a step which most people forget but is KEY when using the stuff. Spread a thin layer of the glue over the bar and slip the grip on. You have a few minutes to adjust it how you want which is nice. 4 hours later and it'll be on there like iron and its not going anywhere for a while!
Old 08-14-2018 | 10:04 AM
twoglides13's Avatar
twoglides13
I never use glue when I replace grips, and have never had one come loose. Maybe it has something to do with buying the right grips.
Old 08-14-2018 | 10:54 AM
Uncle Peepers's Avatar
Uncle Peepers
A number of after-market grips done' require glue, Avon among them. For those that do, I've never used anything buy hairspray and never had a problem.
Old 08-14-2018 | 01:26 PM
t059736's Avatar
t059736
Thank you Riders for the great advice.
I went with the double sided seemed carpet tape and the "stickiest" hair spray on the market.
Seems to have worked - REALLY GOOD.
Thanks again for all the responses......
Old 08-15-2018 | 12:41 AM
darkcustom7's Avatar
darkcustom7
I've always used rattle can clearcoat. spray it on the bar and the inside of the grip.
caleborlando`
General Topics/Tech Tips
04-28-2016 09:49 PM
Prot
EVO
13
07-08-2014 02:21 AM
pomeara
02-01-2014 09:03 AM
2007fxdc
12-10-2009 09:01 PM
harley0711
08-16-2006 12:52 AM
Quick Reply: Left hand grip removal and re-Install
