Stumped
Noise stays the same, that's why I haven't thought it to be the primary bearings. Thanks for clarifying brother.
If your compensator nut was loose, the only thing driving the alternator rotor was the Belville spring. If all you did was tighten the nut, you probably missed the spine gone. The face wears, and the sprocket moves over and the chain nips the sprocket since there is only .030 clearance for chain misalignment. What happened to mine. Mine then made an odd clicking noise in slow hard
left hand turns. .
left hand turns. .
Mine has always made a hunting scraping sound at idle when hot at red lights from the compensator fingers being a little gaulded. The compensation got loose or alternator spline went at around 10k. Dealer tightened it back up twice under $100 copay warranty. Third time, I took it all the way apart when face had worn so far and gear had moved over. They told me they would not honor warranty since I had showed them up by taking it apart. After a little argument they game me 10% off on parts. I cut all my love for them off after the third screwing.
Like I said above, the noise with the chain nicking was a low slow tick. (The parts man told me he had sold a dozen rotors that year)
Originally Posted by ScottHart
Well, finally got some time to bust a move on this deal. And it is the outer cam chain tensioner that was making the noise like a bearing going south. So glad I didn't listen to some and keep riding. Could have been a big issue at the look of this.
