AIr Shocks only one sidetaking air
08-05-2018, 09:54 AM
03 Road King rear shocks only one seems to be taking air and I can only get about a 6 lb reading on the mannual air pump???
08-05-2018, 10:17 AM
08-05-2018, 10:19 AM
Have you followed the air lines to the otherside not taking air?
First post and all...
Rob
08-05-2018, 10:23 AM
Quote:
Originally Posted by
CndUltra95
Rob
This problem is highly unlikely...I call OPW...again.
08-15-2018, 05:57 AM
Yep
Check that airline that connects the two shocks.
As for the pressure issue you should be using a zero loss pump for shocks. A regular pump will allow the air to bleed out and of course it never hurts to change your shrader
08-15-2018, 06:09 AM
Are they on a common line right?
so if one leaks the other will too.
Go to marine hardware store and get a tube of 3 M 5200
comes in black or white.
Use it for a sealant around the brass Farrel and nuts.
Not much
.Let it set overnight as a minimum.
The plumbing will never leak again.
08-15-2018, 06:31 AM
The best cure for this problem is to remove said air shocks and promptly throw them in the nearest dumpster.
08-15-2018, 06:39 AM
Gunrunner72
Agree with gunrunner, dump the air and go with coil overs. Vast improvement.
08-15-2018, 06:57 AM
Troll post by the OP, folks...I say again
EddieWard
02-10-2018 10:28 AM
berndog
10-26-2012 04:49 PM
Mark MPDC
02-15-2010 05:33 PM
Biker_Bob
04-25-2009 07:38 AM
harleyflo
01-30-2009 02:04 PM
