Got a 2018 SGS that I put a detachable tour pack on. The thing squeaks like a ****. Believe it’s coming from the lid. Anyone else have this issue and what’s the fix??
Mine squeaks at the latch where the two pins on the lid go into the locking mechanism, found it by putting soap on the pins wish I could find a fix for it
If the lids are not closed tight they will squeak a lot try adjusting them and check the rubber gasket.
Brand new TP, so I assume gasket is ok. I will try adjusting the latch too. I didn't think it could be adjusted but maybe it can be shifted slightly. Thanks, I will try that too
