No Spark Rushmore
No Spark Rushmore
2016 police edition touring model: A friend of mine wants to install a boom radio with nav so we found the radio and installed it with a new fairing harness. Also bought a 2014 Ultra Classic main harness and replaced the police edition harness. We got everything working great, radio nav with all the controls working fine. All the lights work perfect. The engine will turn over but will not start. Keep getting a code p2300 front ignition coil driver low/ open and p2303 rear ignition coil driver low/open. Does anyone know what the coil driver is so we can troubleshoot. We inspected the harness a few times for broken wires and made sure all connections are made correctly. actually tried another ecm and bcm with matching fob from another bike that was running and the same code shows up and will not start. The bike didn't come with security. Any ideas on troubleshooting this would be appreciated. is the coil driver the ecm ? Does it need re flashed?
No codes showing for the crank sensor either.
pabowhunter
04-13-2019 06:39 PM
Ing. Robert Forbus
06-17-2007 12:05 PM
