Bike running rough, throwing code P0118
Hey guys, need some help.
Bike is a 2012 Limited with 55K miles that has never given me any problems.
Recently, engine light comes on and bike runs really rough for a few seconds and throws code P0118.
Code P0118 relates to the Engine Temp Sensor. I replaced the Engine Temp Sensor, and it didn't fix the issue. Somewhere I read that sometimes the Crankshaft Position Sensor causes the same code so I replaced it as well but the problem still exists.
This is an intermittent issue, bike usually runs fine, although it's happening more and more.
I've cleaned and checked the connector and pins that connect to the Throttle Body.
Don't know where to go from here, anyone had a similar issue and found the problem?
