I had seriice code on 117/118 on my 2013 Road Glide. After a lot of voltage and resistance checking and replacing the sensor I replaced the female plug on the sensor with one I purchased from Advance Auto Parts. So far all good.
For anyone interested, dealer called, sounds like the problem was the wire/pin on the female side right where the wire connects to the sensor. Makes sense I guess that this would be the weak point with all the engine movement. Pisses me off that I couldn't find it. Dealer had to order the connector and pins and is also replacing the pins at the throttle body just because it's a problem area on a bike with my mileage.
Planning a ride with HOG group this morning....stopped for gas and entering the interstate, bike cutting out, no power and check engine light came on....cleared it up and continued to the HD shop. Had Service Writer check codes.....P0108 came up. Returned home asap (17 miles), exited off interstate and bike was not running well.....backfire on decel and couldn't keep idle up....coasted last 3 miles to my driveway. HD dealer picking up trike tomorrow. 2013 Tri-Glide with 43,600 miles on the clock. (Side note: last couple rides was acting up, but only for a few minutes, then cleared up).
