Poor man's fork spring compressor tool?
RE: Poor man's fork spring compressor tool?
Those idea's might work with a conventional fork, but on the '06 flht, the forks have a damper cartridge. After the fork tube plug is removed, and the spring is exposed, you need to compress the spring to remove the "jam nut" and release the spring from the fork tube.Still looking for an alternative.
Dougbk,
I read your response, thought about it, watched the video again of the fork disassembly. I believe a person might be able to "muscle" the spring on a damper type fork and remove it. But to reassemble it, you would need four arms to compress the spring, hold the damper cartridge up, and thread the jam nut onto the damper all at the same time.
