Trouble installing new security system on '15 FLHR
So I just bought a '15 FLHR that did not have the security system installed. I bought a brand new one off of a dealership on Ebay. I installed the physical module and antenna, took 5 minutes. My problem is that now my bike won't stay running. It will start but immediately stalls. I followed the directions as per the TSM/TSSM ECM Password Learn Procedure, twice, but no change. The ones I found on the net are slightly different from the ones in the book, which I also tried. The steps I tried are located at https://www.justanswer.com/motorcycle/6zolf-when-installing-harley-security-system-ultra-classic.html.
A couple of things. On step 3 in the book, when I hit the right turn signal, after toggling the left turn signal 2x, it should display the current code but nothing is displayed other than the mileage. So basically as for the book directions, I can't proceed because this is where I would set my pin. Also, I assume that the red light just to the right of the speedometer needle is the security lamp. There is no key lamp as there is on my DWG so just guessing here.
I know I need to take the bike and fobs to the dealership to have them mated but figured I would be able to ride there. Am I doing something wrong, do I have a bad unit or is this part of the mating process the dealer has to do?
I just went thru this on my 05 FLH but as you know the procedure is different from your bike to mine. I did not have to use the right turn signal button at all. I follow the procedure even using my cell phones stopwatch app and first time she took. Is this the procedure that you used?
http://www.harley-performance.com/password-learn.html
So I had the dealer flash my ECM/TSSM yesterday and now everything is working great. I guess on the '14 up bikes the self programming steps mentioned previously no longer work. Now the dealer has to not only marry the fobs but also flash the module. Cost me $63.72 for the flash job and I paid $306 for the brand new unit so I figure I'm still ahead.
Sarge 154
10-11-2008 10:10 PM
