21 inch wheel
Old 07-24-2018 | 06:36 PM
Roli's Avatar
Roli
Default 21 inch wheel
I just got me a 2015 Road glide a couple weeks ago. It has a 21 inch wheel. For those who have a 21 inch wheel is the riding much different then a stock wheel? anything I need to watch out for? Thank you in advance for your feedback.
Old 07-24-2018 | 09:40 PM
sanman4ever's Avatar
sanman4ever
What size wheel is on the back? Any modifications done to the front suspension?
Old 07-24-2018 | 09:56 PM
Roli's Avatar
Roli
Stock. And don't know about front suspension. It looks stock.
Old 07-24-2018 | 09:59 PM
jjkrueg's Avatar
jjkrueg
I don't notice any ride difference on mine. 2018 CVO Road Glide with 21" wheel.
Roli (07-25-2018)
Old 07-24-2018 | 10:43 PM
Nitrochicken's Avatar
Nitrochicken
21/16 here. Front lowered with Monotubes. No difference that I can notice versus stock set-up.
Roli (07-25-2018)
Old 07-24-2018 | 10:50 PM
sanman4ever
Did you feel it needed to be lowered to preserve the ride quality? How much did you lower it?
Old 07-25-2018 | 12:01 AM
Nitrochicken
I never rode it with only the 21. I did everything at the same time and honestly feel no difference from stock to 21. Hope this helps.
Roli (07-25-2018)
Old 07-25-2018 | 01:11 AM
Guntoter's Avatar
Guntoter
Run the air pressure at 42 psi, never, ever let it below 40 psi or you risk bending the wheel on hard bumps or potholes. Lowering the front end at least an inch, 1 1/2" preferably, will bring the front end back to about the same height with the stock wheel, however you then bring the fender closer to the triple tree and the oil cooler/water pump located at the bottom front of the frame where contact can be made. Make sure the tire has clearance in the fender by taping a 5/16 nut to the centerline of the tire and spin it, making sure there is no fender contact.
The following 2 users liked this post by Guntoter:
Roli (07-25-2018), SPR (07-25-2018)
Old 07-25-2018 | 07:01 AM
Roli's Avatar
Roli
this is one beautiful Bike you got!!
Old 07-25-2018 | 09:28 AM
Veekness's Avatar
Veekness
This may or may be germane to your situation, OP, but several years ago I had a bike that a buddy and I built from frame up, based on a 1985 FXWG frame. Initially, it was configured like a Heritage, with 16's front and back. I went to a Wide Glide configuration with a 21 front, kept the 16 rear.
Man, what a difference, and NOT in a good way! The handling completely changed, and it was hard keeping up with my pals on touring bikes in the twisties...
I've come to the opinion that tires of radically different sizes and profiles front and rear is not conducive to decent handling. So, OP, if you like the look of that 21, I believe you may pay a penalty in handling.
Roli (07-25-2018)
