Primary drain plug crap...
07-22-2018, 09:34 PM
Another pic...
07-22-2018, 09:40 PM
07-22-2018, 09:44 PM
Quote:
Originally Posted by
6113_
did you happen to run a magnet through the oil that you drained out?
no :-(... wish I had.
07-23-2018, 12:33 AM
Had about that much total from both the 1,000 and 10,000 primary changes put together . Pull the cover but couldn't see any thing, 55,000 miles showing now and just replaced the starter, other then that its all been good.
07-23-2018, 12:48 AM
Normal. Most likely bits of clutch pad break-in I had same first oil change in primary.
options, take a telescopic magnet down below clutch and see if you pick up any more.
Or take some time to remove cover and visually check.
07-23-2018, 04:09 AM
These are metal parts right?
friction material is NOT, sometimes they sneak a powder in , not chunks.
07-23-2018, 07:18 AM
07-23-2018, 07:27 AM
i would reuse the gasket. my primary has been off of my 85 countless times in the 33 year i have owned it. i'm on my 3rd gasket.
07-23-2018, 07:35 AM
07-23-2018, 07:40 AM
14GuineaPig
20,000 miles
Here's a photo of mine at the 20,000 mile service. I now have 100,000 + miles and the primary has still never been opened.
Deleted
