You have a gas smell or fuel spilling out of your cap?
In this heat you may be experiencing fuel smell or gas spilling out from under your cap after a fill up...
You should check your vent tube by blowing through it... disconnect the rubber hose connection from under your dash panel and make sure it is easy to blow through. If it is, then you or the bike's previous owner have probably been over tightening your fuel cap. In my case I bought an out of lease police bike and this started happening to me this summer. A new gas cap fixed the problem.
Going to disagree a little with you on this. At least for what I know on a non CA canaster bike.
The vent hose in the top front of the tank goes I to a vertical held check valve that has resistance but does go one way out. That resistance is to prevent raw liquid fuel from surging fwd in tank.
Something wrong with a 2014 gas cap being bad...
It vents vapor under a slight pressure build up. The one way vent in and to also let fuel pump work correctly is the vent one way in cap.
There is some non vent generic caps out there and some people stupidly remove the vent hose check valve. The get raw gas coming out vent hose. Stinks up garage and can be a fire danger.
A new cap allowed me to fill the tank the way I always have... and that is just below the inner hole in the tank structure... not above it... which is full to me... and I never over clicked my cap once that became a 'feature' of HD caps.
There’s many ways to skin a cat just like there isn’t one concrete reason why someone may be smelling gas around their bike.
SublimeSubdue
10-07-2016 03:44 PM
