Scraping noise under my bike
Check your kick "Jiffy" stand and make sure the spring is pulling it tight to the frame when you are riding. The spring will wear over time and the stand can hang lower than it should and the dip could be causing it to drop a little more as well.
Another thing you can do is get down on the ground with a flashlight and look for shiny scraped spots especially on the jiffy stand if you really feel the frame is bottoming out.
Good luck!!.
Good luck!!.
Good luck!!.
Good luck!!.
Beary
