2006 oil cooler gasket install leak
Old 06-26-2007 | 09:30 PM
j_anf's Avatar
j_anf
Default 2006 oil cooler gasket install leak
I have been trying to install a new oil cooler on my '06 Ultra. Can't get the gasket to seal. What's my problem?
Old 06-26-2007 | 09:42 PM
notorious's Avatar
notorious
Default RE: 2006 oil cooler gasket install leak
Need more info and pics to diagnose.
Old 06-26-2007 | 11:10 PM
fatboylust's Avatar
fatboylust
Is the adapter between the engine and the filter a one-piece unit [P/N 26133-07](like that shown in the upper right of attachment 1) or the two-piece like the Jagg's (shown in attachment 2) unit with a gasket between the two halves? In any case which gasket in the assembly is leaking?
FBL
[IMG]local://upfiles/10879/CC4CAD9B51664635A4C74E78BC2140D7.jpg[/IMG]
[IMG]local://upfiles/10879/F11FFFE2C4D34E458C8B8DCB0C47D955.jpg[/IMG]
Old 06-27-2007 | 12:57 AM
j_anf's Avatar
j_anf
It is the top picture of the HD model.
Old 06-27-2007 | 10:37 AM
Softtail Bob's Avatar
Softtail Bob
Are you sure it's leaking or is it just the oil from the install thats still dripping? I thought mine was leaking but after I washed the area real well with WD-40 followed by soap and water there was no more oil drips. It is really no different than an oil filter gasket and should not take to much to make a good seal.
Old 06-27-2007 | 08:38 PM
j_anf's Avatar
j_anf
It just gushed out around the gasket side of the adaptor. Probably 1/2 pint of oil loss. Gasket was smooth with no tears. Is it possible I over torqued it?
Old 06-28-2007 | 12:47 AM
Softtail Bob
Well because the adapter does not spin around, you tighten it up using the oil filter adapter bolt, I don't see how it could really get damaged during installation. I would say pull the oil filter off and remove the adapter to see if the gasket is damaged.
Old 06-28-2007 | 12:57 AM
j_anf's Avatar
j_anf
I did take the adapter bolt back out to check the gasket. It does look like I have compressed it quite a bit. 12-16 ft. lbs. isn't any tighter than the oil filter is it. I cranked the adapter down pretty hard after it leaked the first time and it's a lot thinner than originally out of the box.
SG103
Oil Archive (no new posts)
03-29-2017 06:25 PM
RVTRKN
04-27-2014 02:56 PM
notrailers
07-16-2011 12:20 PM
jcanrun
04-23-2010 02:37 PM
dontdropit
09-08-2008 07:03 AM
