Rear pulley: Do you re-torque yours?
Campy Roadie (07-02-2018)
Bone Doc (07-02-2018)
No, do not re-torque these; you can break the threadlocker loose, and loose the elastic holding power of the stretched bolt.
Nomadmax has a great idea. I check mine by putting a wrench on the bolt a tapping it very lightly with a small ball peen hammer, you get a tink sound if they’re tight. If you get a thud, they’re loose and you’ll need to install new bolts.
Rotor bolts can be reused up to 3 times according to the service manual, now before anyone starts flaming me that is listed for some years and not for others so follow YOUR manual if so inclined. Think about it this way the bolt is steel, the hub it threads into is aluminium. Which is more likely to get damaged from repeated torque? Do you replace the wheel every time you install a new chrome rotor? HD wishes you did.
Just my thoughts
Just my thoughts
Just my thoughts
Just my thoughts
When using rotor bolts that have the factory dry loctite, I think the stretch occurs when you loosen them. My manual calls for replacement but even if it didn't, I'd still replace them. The price of failure is a swing arm and a locked real wheel. I don't know if I'm right so I error on the side caution.
And new bolts are cheap, I don't disagree with you. Just seems to me the aluminum threads would be the weak link?
