High beams not coming on
2015 Street Glide Special
Has anybody replaced your high beam switch?
I lost my high beams, low beams working correctly and when I push the "Flash to Pass" the high beam do light up - so I don not believe that the bulb is bad. They will not come on when the stitch is changed to high beam mode. I don't even get the high beam indicator light on in the dash.
I'm running a JW Speaker headlight, if that matters.
What is involved with replacing the switch in the left hand control module?
Is there anything else I should check before swapping out the switch?
Any help is appreciated.
Thanks,
Thanks,
You can’t replace just the switch any longer. With the change to the CANBUS system, the switches are actually on a small switch board similar to something you’d see in a computer.
If one switch stops working, the whole switch pack has to be replaced. Many people are changing to the lighted switches because the cost isn’t much more than getting another stock switch pack.
