Oil Cooler
Old 06-28-2018 | 02:09 PM
itsmf's Avatar
itsmf
Default Oil Cooler
Are there any advantages to installing an oil cooler on a 2009 Ultra/with 132,000 miles. It also has a stage 2 103 kit.
Old 06-28-2018 | 02:11 PM
cbrenthus's Avatar
cbrenthus
adding an oil cooler is never a bad idea
Old 06-28-2018 | 02:19 PM
MURPHCC1's Avatar
MURPHCC1
I would only go with a FAN ASSISTED cooler myself.......ya dont need cooling at speed......ya need it in stop and go traffic.......same thing with a cylinder cooling fan.
Old 06-28-2018 | 04:38 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Here's a report link on why and how to cool down your TC engine. Check it out.
In it, we go over the advantages of an oil cooler.
Why & How to Cool Down the Twin Cam & Milwaukee-Eight Engines
Here is a LINK to the oil coolers we offer for your bike.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old 06-28-2018 | 07:28 PM
alarmdoug's Avatar
alarmdoug
An oil cooler is always a good idea. Unknown to most your highest oil temperatures are at Interstate speeds when the most air is blowing through the oil cooler
It's it's why just about every brand bike out there that it's rare a fan is ever on a oil cooler.
The only help a fan would do is if you were stuck in traffic and were concerned about your oil temperature but lowering your oil temperature is not going to cool your engine so if you were concerned about the engine overheating an engine fan would be best.
On on the Rushmore bikes 2014 and later I know for a fact the bottom of the Pistons are sprayed with oil at high speeds and that is why the high oil temperatures at high speeds and why Harley-Davidson included oil coolers on these bikes.
Once you slow down to slow-moving roads your oil temperatures drop even though there's less air going through the oil cooler.
I have intensely followed my oil temperature for the last 2 years on my 14 Road King and know for fact oil temperatures run 252 265 degrees 2 up, 90+ degree weather at 80 miles per hour and I have a 10 row jagg oil cooler on my bike which I swapped out from the 6 row Harley-Davidson
Once off the interstate oil temperature drops rapidly because the Pistons are not being sprayed anymore the only time temperature will rise to what they are on the highway is at if you're stuck in traffic, at that point though an engine fan would be better for traffic because oil is not going to cool your engine.
True there is nothing wrong with having a fan on an oil cooler but if you want to have a fan the best choice at that point would be an engine fan.
I don't know the behavior of the pre Rushmore bikes as far as if the Pistons are sprayed to cool them down but if you're looking for a fun project for me personally I would go for it.
Old 06-28-2018 | 07:33 PM
tibadoe's Avatar
tibadoe
A oil cooler on an air cooled engine is always a good idea in my book. I added one to my 09 at the 1k service.
Old 06-28-2018 | 07:51 PM
nobodyknowsme's Avatar
nobodyknowsme
Ya might ask the member that posted this thread.
https://www.hdforums.com/forum/gener...expecting.html
Old 06-29-2018 | 08:12 AM
itsmf's Avatar
itsmf
Default OIL Cooler
Thanks all for your very informative replies,its being installed today.
Old 06-29-2018 | 08:15 AM
scott7d's Avatar
scott7d
Oil coolers and head fans have been discussed a lot on Harley tech talk. There have been a few comparisons and some testing between both methods. In every circumstance, the head fans cooled the oil more than the oil coolers. It was also found the fans used, Love Jugs Mighty Mites, will have some sort of cooling effect up to 50mph. Speeds over 50mph, heat shouldn’t be a problem anyways unless something is wrong with the bike.
I have a pretty good defense against heat. Baker +1.5qt oil pan, stock oil cooler, and Mighty Mite head fans. Even at 11.1 to 1 compression, my EITMS does not kick on at stop lights and in slow construction traffic. When my bike was at stage 1, I could count on it kicking down to 1 cylinder quickly even at stock compression. A friend of mine with a similar build but in a 124” configuration does not see over 210-degree oil temps since installing the fans. My bike is a Road King so I can’t see oil temps on a dash. I didn’t care for the looks of the fans, so painted them granite to match the motor. Now I don’t even notice them anymore. What I love, is that they also cool the heads, not just the oil. Some don’t realize head temps and oil temps are two separate things.
I purchased an Oil Bud oil cooler a few weeks ago and had to send back because of a fitment issue. It may have been a blessing in disguise as I don’t think it was really needed with my current setup. Those little fans are kicking ***.
Campy Roadie (06-30-2018)
Old 06-30-2018 | 01:57 PM
CndUltra95's Avatar
CndUltra95
Not having had one the first 132000 miles of its life hasnt done no harm...
Save the money for gas.
Rob
The following 2 users liked this post by CndUltra95:
Campy Roadie (06-30-2018), lionsm13 (07-02-2018)
Quick Reply: Oil Cooler
