wont shut off
wont shut off
Hi everyone Im new to your forum and could use your help
I have a 06 ultra that wont shut off ( engine will shut down when you turn ignition off)but not anyof the electrical nor if you hit the kill switch
Ive replaced my battery which was old and the two relays located by the battery
electrical only shuts off by pulling the fuse or disconnect battery
If you remove the wires from the ignition housing the electrical ie radio and panel cluster will tun off
could the ignition housing be the culprit ?
electrical not my friend
thanks for any help
thank you
thanks for any help
thank you
Received 4,808 Likes
Prolly need one of these: 61572-06, ignition switch.
Item # 16 here https://shop.outpostalaska.com/OEMpa...06)//SWITCHES_
