Notices
How long to drain a battery?
Old 06-25-2007, 06:45 PM
stro1965's Avatar
stro1965
stro1965 is offline
Default How long to drain a battery?
I posted in general so I won't go into all that again, but how long should a new battery last on an Ultra, assuming nothing was left on, before the battery goes dead? Months? Mine lasted 3 days and the dealer says nothing is wrong and I should have had it on a tender.
Old 06-25-2007, 06:49 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
Default RE: How long to drain a battery?
I answered you there but I'll give you a little different answer here since you worded the question differently.
Congratulations. You just learned a valuable lesson about your dealer. Fortunately your bike is under warranty and you can give someone else the chance to earn your business by giving you a straight answer and really caring about your problem.
Old 06-25-2007, 06:53 PM
FoxRM250's Avatar
FoxRM250
FoxRM250 is offline
Your dealer is so wrong and blowing smoke up your behind. A battery should last several weeks if not longer without going dead. Make sure you don't have anything on thats draining it down, otherwise you have a bad battery.The cold weather will drain one down a little quicker, but this time of year they should stay up for weeks if not months.I don't even own a battery tender and never have dead batteries on my bikes.
Old 06-25-2007, 06:58 PM
Sharknose's Avatar
Sharknose
I noticed that you are in NE...A year ago (to the week, in fact) my wife and I made a 4500 mile circle out west and visited a dealership in Nebraska that was the worst excuse for a dealership I've ever seen. I don't remember the name of the town but it's Johnny Carson's birthplace. We were obviously from out of town and on the road and when we walked in the door everybody looked up at us, then went right back to what they were doing--reading a magazine, talking to each other, etc. We were the only "customers" in the store and were were there for 15 minutes and nobody ever spoke to us, even to say "hello".
Old 06-25-2007, 07:01 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
I agree with FoxRM, in that your battery should not be drained after three days! Your Dealer is blowing smoke big time!
I have had both a Road King Classic and now a Road Glide, and neither has ever drained a battery. I don't even own a battery tender, because I never had a need for one. If your battery drains that fast, you have a short or a bad battery. Most HD battery will last between 18 to 30 months, depending on usage.
From my experience, the battery power can leak through your engine cut-off switch on your right handlebar. It's always a good practice to use this switch every time you shut-off your engine. Don't rely on the ignition switch alone! Harley has a history of battery leakage through the cut-off switch. So, if you shut off this switch every time you park, you should have no battery drainage.
ORIGINAL: FoxRM250
Old 06-25-2007, 07:03 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: stro1965
Do you have an alarm?
Is it setup for auto-alarm?
Or if not set for auto-alarm, did you have it on during the time the battery drained?
It makes a bit of difference.
Old 06-25-2007, 07:04 PM
Avmech's Avatar
Avmech
Avmech is offline
I left mine the bike with no charger all winter, come spring time I pulled the bike out and it fired right up.
Old 06-25-2007, 07:10 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
Ram,
I think even if the auto alarm is on for a week, it should not have drained the battery that fast. I don't know the voltage draw off the top of my head, but I can't imagine the alarm using that much battery juice. Just my own thinking, of course.
ORIGINAL: Ram
Old 06-25-2007, 08:29 PM
choochoo's Avatar
choochoo
choochoo is offline
That would of been in Norfolk, Nebraska.
Used to liver there and I too experienced their apathy.
ORIGINAL: BG Weasel
Old 06-25-2007, 08:36 PM
choochoo's Avatar
choochoo
choochoo is offline
mine sits outside all winter, if lucky under a tarp.
Here in Wyoming, never been dead once.
One day it was 5 below out. truck wouldn't start, but I had to be to work,
on emergency call.
Bike fired right up and the battery was 4 years old.
Another battery original in my 01 flhtci, sat on back porch no tender from feb 2002 until this feb /mar. Put it in bike (it had 4.89 volts) charged it off and on for a few days and it fired the
the bike up.
so yes your dealer is blowing smoke and outright lying.
There is something NOT nomal.
When the bike is running is the volt gauge showing a charge rate of 14.5 ?
If not you probably have lost the stator.
Quick Reply: How long to drain a battery?
