breather bypass
Old 06-16-2018 | 03:47 PM
trunomad's Avatar
trunomad
Default breather bypass
I have a 2011 Ultra Limited with a SCREMIN EAGLE VENTILATOR AIR CLEANER KIT part #29490-09. I would like to install a external breather system. Can anyone steer me towards some company that makes a bolt on system. I tried DK Customs and they said that I would have to make modifications to my air filter for theirs to work. Or will I have to drill and tap my backplate and install fittings of some kind? Anybody else done this? Thanks for any and all suggestions.
Old 06-16-2018 | 04:31 PM
uscanuck's Avatar
uscanuck
You just need to drill and tap both sides of the back plate and install a 1/4" ID hose barb x 1/8" male NPT fitting. Fill the internal drain to the throttle body with RTV and attach a couple hoses to the fittings and run them to ground.
You have to drill the fitting on the left side on an angle to clear the IAC motor.
Old 06-16-2018 | 05:32 PM
soulpatch's Avatar
soulpatch
Almost all of them require some minor work. There are a couple that have different banjo fittings, but honestly can't remember the company name. It's really easy to drill and tap for the fitting though. The placement is on the bottom, just remember to angle them a bit for clearance around the throttle body. Can run braided line, fuel/oil line or 1/4" stainless tubing all easy enough. Some guys run them to a filter, catch can or just bleed to the ground. I'll keep my eyes open when surfing around for parts, may come across those banjo/bolt breathers. I'm pretty sure they are just vented to the atmosphere though. No fittings or lines to run. So could still get some oil misting on the side of the bike.
Old 06-16-2018 | 06:37 PM
trunomad's Avatar
trunomad
Default Breather bypass
I like the look of what you have. That is what I want to do. But I don't know if I can do that with my cover
Old 06-16-2018 | 09:00 PM
Kitsoldman's Avatar
Kitsoldman
I did this with DK customs homebrew kit, bought a brass t fitting from the hardware store. Works great and a pretty clean look.
DK Custom - ST (06-19-2018)
Old 06-16-2018 | 09:05 PM
Kitsoldman's Avatar
Kitsoldman
Here’s the pics
The following 2 users liked this post by Kitsoldman:
Bushy (06-23-2018), DK Custom - ST (06-19-2018)
Old 06-17-2018 | 06:55 AM
soulpatch's Avatar
soulpatch
What's your back plate look like?
Old 06-17-2018 | 07:35 AM
trunomad's Avatar
trunomad
I will take a picture and post later today. Preparing to leave on a fathers day ride.
Old 06-17-2018 | 07:38 AM
twistr's Avatar
twistr
Old 06-17-2018 | 09:44 AM
GhostRiderFLHTC's Avatar
GhostRiderFLHTC
I just installed the DIY DK Customs breather Relatively easy project (I am not mechanic )
I used these tools/parts:
http://a.co/dTWrJTK
http://a.co/ewIwNIn
http://a.co/aKlwyLr
The following 2 users liked this post by GhostRiderFLHTC:
94 ultra (09-16-2018), DK Custom - ST (06-19-2018)
Quick Reply: breather bypass
