Help with gasket placement 07 road king
Old 05-29-2018 | 05:33 PM
Sworrix222's Avatar
Sworrix222
Default Pic
  #32
Old 05-29-2018 | 06:13 PM
Zerk's Avatar
Zerk
I didn't use any special tools for removing my heads, other than dogbones for tqing. But a few I didn't tq on rear cylinder. Next maybe get a 1/4 tq wrench.
  #33
Old 05-30-2018 | 07:32 AM
Sworrix222's Avatar
Sworrix222
Default Twrench
I have three torque wrench is all snap on quarter inch three eights and half-inch I could not get it to fit. I had even drop out the motor mount when I was disassembling. So it would drop a little farther. I bought a tool from motion pro that supposed to be a torque wrench extender and it broke. No big deal I took a 7/16 Socket and ground about a quarter inch off of it and it works perfect.
  #34
Old 05-30-2018 | 05:40 PM
Sworrix222's Avatar
Sworrix222
Default Camplate
Ed do I need to use blue Loctite on the cam plate screws and oil pump screws?
  #35
Old 05-30-2018 | 08:33 PM
dawg's Avatar
dawg
Dog bone torque adapters are what you use.
  #36
Old 05-30-2018 | 08:35 PM
dawg's Avatar
dawg
what does your manual say?
  #37
Old 05-30-2018 | 09:36 PM
Sworrix222's Avatar
Sworrix222
Default Nothing
It doesn’t say to use Loctite in the manual unless I overlooked it and every video I have watched they are using blue Loctite
  #38
Old 05-30-2018 | 09:46 PM
dawg's Avatar
dawg
Yes, many use blue loctite on the fasteners. Be sure to torque the cam plate fasteners that go through the dowel pins on the lowest setting (90 inch lbs IIRC) as they are easy to strip. An alternative is to replace those ones with studs and 12 point nuts. Also be sure to center the oil pump as you tighten the bolts either using centering pins or rotating the rear wheel and alternately snugging the appropriate bolts.
  #39
Old 05-31-2018 | 07:08 AM
Zerk's Avatar
Zerk
Thats what I do.
40k since I built it.
  #40
Old 05-31-2018 | 07:26 AM
Sworrix222's Avatar
Sworrix222
Default Thanks
thanks guys I got the oil pump in the cam chest done going to finish the top and get it started up tonight.
Quick Reply: Help with gasket placement 07 road king
