Help with gasket placement 07 road king
Old 05-28-2018 | 08:20 PM
dawg's Avatar
dawg
Shorter bolts and different torque than listed in your manual....120-156 inch lbs
Old 05-28-2018 | 08:23 PM
Sworrix222's Avatar
Sworrix222
Default Breather
I would assume you pitch the old one and use the new set up?This came in the factory Harley top end gasket kit.i assume this is the way it goes together?
Old 05-28-2018 | 08:25 PM
Sworrix222's Avatar
Sworrix222
Default Sorter bolts
Yes there are shorter bolts. 120 to 156?
Old 05-28-2018 | 08:34 PM
dawg's Avatar
dawg
120-156 inch lb torque
Old 05-28-2018 | 08:37 PM
dawg's Avatar
dawg
Old 05-28-2018 | 10:56 PM
Sworrix222's Avatar
Sworrix222
Default Breather
Thanks Does it go together just like that picture you sent it doesn’t seem right that way?
Old 05-29-2018 | 05:30 AM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by Ed Ramberger
The tool that fits in the center of the bolt and the tool that helps remove and install the bolts inside the rocker cover are not for torquing or breaking things loose. Those two tools just make it nicer to remove and install. You don't need any special tools except proper size torque wrenches and dogbone torque adapters through all of this. You do not have to remove any motor mounts. The rear lower rocker box goes in with the rockers bolts and breathers in - you just lift the bolts over the head and under the frame.
I meant to say Rocker plate goes in as an assembly and slips over the lower rocker box and under the frame.
Old 05-29-2018 | 07:09 AM
Sworrix222's Avatar
Sworrix222
Default Breather
Yep I’m good on that ed. I’m just trying to figure out how that breather goes together it was in separate pieces. The picture that DAWG sent doesn’t look right if you put it together that way. I put it together kind of in the same orientation has the stock one I posted a picture can one of you guys tell me how it actually goes together?
Old 05-29-2018 | 07:41 AM
Ed Ramberger
Orient it like old one. Filter to head, top of umbrella valve to sky. Cover on top covering it all.
Old 05-29-2018 | 01:50 PM
RevBlk's Avatar
RevBlk
When I changed my cams I also put in the updated breather filters. I also reamed the drain hole to allow better draining of oil from the top end as was recommended. I think it was a .125" bit. If you search you will find it on here. Apparently it reduces misting into the air filter. Seemed to work on mine but I don't know if that is because of the new breather filters, the drain hole modification or a combination of the 2.
Quick Reply: Help with gasket placement 07 road king
