94 ultra tour pak removal??
Old 01-27-2005 | 10:53 PM
barhpr's Avatar
barhpr
Default 94 ultra tour pak removal??
I cant find a kit to make my tour pack a quick disconnect,has anyone ever removed thiers,and if so,how much is involved in the wiring?
Old 01-28-2005 | 01:42 AM
luvmyflhtcui's Avatar
luvmyflhtcui
Default RE: 94 ultra tour pak removal??
They have not made a quick disconnect wiring kits for the Ultra as there are so many wires involved with the stereo/cb system for the back seat. The quick disconnect hardware is going to be the same for the FLHTC. You are going to have to purchase an antennae relocation kit and then it will take some creativity to make your own quick-disconnects for the harnesses. You can buy plugs and jacks from Radio Shack or any electronic store and then it is just a matter of putting them in. Keep in mind that once you cut the wires you can't go back. Be careful and good luck.
Old 01-28-2005 | 02:02 AM
barhpr's Avatar
barhpr
thanks looks like i might as well buy some of them fuses while im at radio shack,lol
Old 01-28-2005 | 02:11 AM
barhpr's Avatar
barhpr
[&o]
Old 01-28-2005 | 12:22 PM
Scout's Avatar
Scout
I did mine. The wiring is not a big deal. Go to a marine shop and buy a water tight case and cut the wires and put together a disconnect for inside the case. I put speakers in my lowers with a toggle switch to activate when I don't have the beer box on. Yeah it took a few hours, but worth it in the long run. I move the antenna's, so I only had to worry about lights and speaker connections.
soon to be
08-30-2022 10:42 AM
BigBrad
03-15-2022 08:35 PM
nivensid
01-23-2014 09:45 PM
orangecamaro
09-03-2007 01:07 PM
bemisbunker
11-10-2005 01:00 AM
Quick Reply: 94 ultra tour pak removal??
