New Throttle cables a tad stiff
Just replaced my throttle cables on my 2003 road king classic. I bought factory cables, routed them exactly where they were and did not touch the cruise in any way. I have a service manual and adjusted the PULL cable as per instructions until the throttle was at WOT. The idle cable was at full slack. According to the Manual. The throttle will return on its own but doesn't snap back like it did. The cruise now doesn't work either. It states that there is no need to touch the cruise and I didn't. What is going on? I don't have any mounting clamps too tight either, I checked all that and took my time putting these on. I even cleaned the spring on the butterfly with carb cleaner and lubed it up as well. The idle cable to me on anything more than a 1/4inch from full slack tends to stiffen up the cable so I have it at full slack. It is also the cable that has the cruise electrical connectors on it.
Any ideas would be a help.
randy
randy
Loosen all he screws at the switch housing and I bet it will loosen right up. Slide it off the handle bar slightly and screw it all back down again. It needs just a little slop.
That or since your bike still has throttle cables, it's over ten years old. It's time for an upgrade
