I have a 2011 FLHTK that I installed an LED lights from Dynamic Customs that serves as turn, brake and running lights. I have an issue with the lights when the emergency flasher is engaged, the right side flashes as though the right turn signal was turned on. Any thoughts?
With the emergency flasher, 4 way flashers, turned on, shouldn't both tour pak lights flash with your setup? You might want to call Custom Dynamics and see what they advise. Their customer service is very good and they are helpful!
Good Luck,
Phil
I agree with Phil. Call dynamics up and go through it with them. It sounds like an error in their controller. I'm assuming that your normal left turn signal works correctly. So it's only not functioning when it's in hazard mode. May just be a faulty unit.
