Pipe change - 3000 RPM stutter
Old 05-08-2018 | 07:42 AM
Br125's Avatar
Br125
Originally Posted by 1Canuck
care to highlight the part I got wrong!
There are mixed opinions for sure. post 8, a pro tuner disagrees with you..
Do you have the device? Have you personally downloaded the software and altered a map and flashed a tune on a bike with the orange super tuner?
It's not opinion, it still works just as it did before the EPA debacle. You don't have to believe me, go ahead and try it out yourself.
Old 05-08-2018 | 07:57 AM
1Canuck's Avatar
1Canuck
yes I have the device. I also have several versions of the software including the latest. But I only use the 2012 version software. I just change the date and it does not require an update be done. I have looked at updated software and on the surface it only has tunes for the most recent year bikes added, so why is it mandatory to update software if you have no need of tuning files for newer bikes, I ask.
so why should I go ahead and try the latest software when the older version works just fine?
Old 05-08-2018 | 08:00 AM
Br125's Avatar
Br125
The new software was not missing any tunes in my experience, at all. It worked just as the old software did.
In other words, works fine.
Old 05-08-2018 | 08:05 AM
1Canuck's Avatar
1Canuck
BS. The 2010 version did not have tuning files for the 2011, 2011 did not have 2012 and so on.
Do you actually have the tuner and look at the software when it updates as to what it says is new.
Old 05-08-2018 | 08:08 AM
scott7d's Avatar
scott7d
It's been mentioned already, but in the midst of the arguments just wanted to reiterate that going from a true dual setup to a 2-1 is a drastic change. I would get it tuned ASAP.
1Canuck (05-08-2018)
Old 05-08-2018 | 08:10 AM
Br125's Avatar
Br125
Why would 2010 software have tunes for newer bikes?
​​​​​ I've used this device on multiple bikes with the newest software. There are no EPA limitations. You can believe what you will.
Again, as mentioned, I'm assuming he has the orange pro tuner that many mistakenly call the "race tuner"
Old 05-08-2018 | 09:09 AM
steelpony16's Avatar
steelpony16
When I switched from a 2-1-2 to a 2-1, I also stuttered at 3000ish RPM, Emailed Fuel Moto, received new maps to try, Problem Solved!
Old 05-08-2018 | 11:51 AM
Puglia10's Avatar
Puglia10
I honestly dont know much about any of the tuning stuff. First bike without a carb.
Its an orange plastic rectangle that says Screamin Eagle on it, in a small white box. I didn't get anything else...when you say software, is there supposed to be a CD with it or something?
As for the dyno...best guy around is booked til MID JULY so calling around....cant have it sit for 3 more months. Ugh.
Old 05-08-2018 | 12:17 PM
1Canuck's Avatar
1Canuck
does it have a black button? If not then it is an older SERT which is much more difficult to get software for.
Yes the early version came with a CD. If you do not have that then you would have to download the most current software.
Old 05-08-2018 | 01:59 PM
steelpony16
Call Fuel Moto and get a new tuner ?
Sierra977
The Dyno Room
12-14-2016 11:13 PM
quinton82
06-24-2015 06:33 AM
RLE
23
07-31-2014 02:42 PM
mgmmgm
08-26-2012 01:35 PM
Overdose
06-02-2012 12:07 AM
Quick Reply: Pipe change - 3000 RPM stutter
