2008 Ultra loud clank on startup, new SE Comp - HELP
Old 05-08-2018 | 08:34 PM
F150HD's Avatar
F150HD
Originally Posted by btsom
Did your compensator come with any shims? Harley had some trouble with quality control on the springs and some new compensators were loose from lack of spring pressure. Installing one or both shims should provide more spring force and keep the moving pieces from hitting the stop. If there were no shims in the kit, check with Harley for a shim package, I believe it sells for less than $10. Something has to be wrong, I suspect something like the cupped side of the smallest spring facing the rotor instead of facing the sprocket, but I wasn't there to watch the install.
ok...maybe this is why there were no shims in my kit. Interesting....I read dozens of threads on the HD forums about the SE comp and never saw any mention of shims. (talking SE comp not Baker comp)
https://www.cvoharley.com/smf/index.php?topic=102511.0
sudz55
05-06-2018 06:44 AM
Outastep99
08-27-2017 05:54 PM
Big_Al47
05-10-2017 07:31 PM
kylebryan
03-29-2016 01:06 PM
Screaming Eagle C.J.
01-07-2014 08:54 PM
Quick Reply: 2008 Ultra loud clank on startup, new SE Comp - HELP
