Front brake vs rear brake when to use which
I pretty much agree with most comments above except for the above quotes which very easily could get you sliding down the highway laying down in a panic stop unless you have ABS. There is good reason why bikes with linked brakes normally apply more front than rear. There is also a reason why the Rushmores unlink below bout 25 mph, allowing use of rear brake only at low speeds.
I really try to use both brakes all the time above 25mph favoring the front so it is normal to me in a panic stop. I do admit I have gotten a bit lazy on my Rushmore and use just the rear sometimes as it also applies left front brake while the front applies all 3 and the ABS determines the ratios as needed. I try not to rely on it too much because my other bike doesn't even have ABS.
I find most of the time if you are aware of your surroundings most stops are slow and controlled. You have no need for rapid stopping.
That being said I also regularly practice quick stops from speed so I have the skills when needed.
Rear brake is for riding cones and slow speed maneuvers...
Out on the road, I rarely use my rear brake unless I really need to scrub off some speed a lot faster then I can with the front brake alone...
NEVER EVER EVER use your front brake with the wheel turned... it will suck you to the ground like a magnet to steel!!!
Good Luck!
RON
Good Luck!
RON
I should have mentioned I have abs and linked brakes. So even though I only use my foot brake I am technically applying both when braking at speed. I always hover my front hand over the brake lever and use it when needed to stop quickly.
Good Luck!
RON
Good Luck!
RON
I've been watching the "ride like a pro" videos since I bought my Ultra Limited last Sunday and it seems that the back brakes should be used a lot more than what I am doing. It seems that rear brakes are preferred over front when doing slow speed turns like u-turns and sharp turns at less than 10 miles per hour. They also seem to be preferred for coming to a complete stop like at stop signs, stop lights and parking. Am I correct in my understanding?
What other times is rear braking preferred over front?
Should front braking mostly be used in those O'SH** moments?
I have been using front brakes for tight low speed turn practice in a parking lot. That has led to some pretty scary moments especially in right handers for me.
Thanks
Wade
Thanks
Wade
Rear brake isn't "preferred", it's MANDATED!! LOL!!
Jerry Paladino's Ride like a Pro series of videos is outstanding! But in addition to his videos, I would HIGHLY suggest that you enter one of his CLASSES. You can certainly learn a lot from videos, but there is no substitute for a pair of PROFESSIONAL eyes looking at you while you are performing some of the exercises, and giving you tips on what you are/are not doing correctly. That is an advantage you don't have when practicing alone.
Here's an example: Use of rear brake "myth". I say "myth" with tongue in cheek. Here's what I mean. You hear "rear brake only" in slow speed maneuvers. Well, you use your rear brake, turn your head and shoulders, looking where you want to go, apply your rear brake, and BAM!!!, down goes the bike! What the heck happened? I did all of the things Jerry said and STILL dropped the bike. This stuff doesn't work, darn it!!! Sound familiar? let's drill down and see what really happened.
This is where the set of professional eyes comes into play. For those that think just because you are using the rear brake when you are leaned over in a u-turn maneuver you will not go down, think again. If you are applying TOO MUCH PRESSURE (with your foot) on the rear brake, it will overpower the amount of throttle and friction zone you are using, and it will stop the rear wheel from turning. And when that happens, the bike goes down quickly. Only at a class could a professional pick up that error in technique.
I learned about the amount of pressure need on the rear brake from Jerry himself. I put my hand down on the rear brake brake pad and asked him to step on my hand with the same amount of pressure he used on the brake in a u-turn. I was AMAZED!!! He BARELY touched it!! So when you hear "use the rear brake", it means to "lightly" apply pressure to it, not stomp the crap out of it! LOL! By lightly applying the rear brake, it has the effect of stabilizing the bike. which makes it easier for the bike to keep turning in a circle to complete the u-turn without falling over. Too much pressure DE_STABILIZES the bike, and it falls over.
Wade, I know you have motorcops up there somewhere close to where you live. Find out where they do their monthly practice sessions, and go to a few. Ask them questions. You'll find out they are VERY willing to help. Get to know them. They are great folks. And when you see them out on the road, wave at them! They will help you TREMENDOUSLY!!!
The following 2 users liked this post by GOV5:
mctraveler (09-11-2019),
SCGamecock (05-14-2018)
Harley ABS
Haven't seen the riding like a pro series but I can tell after riding for 50 years, some of it spent on a race track, your front brake has all the stopping power. So if you are going at speed you depend on the front brake to get hauled down in a hurry. Of course you want to use a combination of front and rear but the front is going to do all the work. Walking speeds in turns are a different story. Like in the previous post you should get slowed down before the turn but when you are going in too hot you want to use the back brake only. With the wheel turned at walking speeds using the front brake aggressively will lean the bike over which can cause you to fall. Using the back brake only will slow you in the turn without changing the attitude of the bike. My .02 YMMV
The other time I use back only if I slowed to a crawl and coming to a stop at a light. No front end dive with back only.
