Front Brake Drag
Front Brake Drag
Hi Guys,
How much brake drag is normal on an FLHX?
I just had my brakes serviced (thanks, recall!) and the ABS module replaced (boo, recall!). I brought the bike home about a month ago and it's pretty much sat since then.
Yesterday, I jacked the bike up and detailed it. While cleaning the front wheel I noticed the front brake seemed to drag more than usual. When I took it for a ride, I could actually hear a wishing noise from the front, that went away when I squeezed the front brake. I think I could actually hear the pads dragging on the rotor.
I decided the best course of action was to turn the radio up and head home. I expect the pads will wear off sooner or later, but do you think the HD shop gakked my brakes up somehow? The headers are in tight and I see no signs of an exhaust leak. Motor mounts are tight.
Thanks,
PPearl
Thanks,
PPearl
On my 09 FLTR I've had to clean the front brake caliper pistons a few times to free them up to reduce the brake drag. There's no protective boot on the piston so over time you'll get a build up of brake dust and road grime that can impede the movement of the piston and cause varying amounts of drag. They're not hard to clean if you're slightly mechanically inclined. Remove the calipers one at a time and install a paint stirring stick between the brake pads to prevent the pistons from coming too far out. The paint stirring stick is a little thinner than the brake disc so the pistons will extend further out to allow better cleaning when you squeeze the lever. Keep an eye on your brake master cylinder when cleaning them since the brake fluid level will drop as the pistons extend. Spray the pistons with brake cleaner and brush with a tooth brush . Pretty easy.
My ‘03 FLHTCI requires front brake calipers be cleaned every 30-45 days depending on trips. The brake dust and grime will cause “sticking” you’re feeling.
With the bike outside, grab some brake cleaner and spray onto a clean rag then wipe those rotors. Quick and easy and should quiet it down and free them up a bit.
Slight drag is normal.
Sauls (05-02-2018)
