2010 Road Glide Custom FLTRX
04-29-2018, 02:57 PM
What is a good setting (psi) on my rear suspension? I have 40 now riding solo & its a ball buster when hitting a bump....I was told dont go under 40 psi ???
04-29-2018, 03:24 PM
Are you sure your not bottoming out? If it’s that much of a ball buster, this could be the case.
04-29-2018, 03:45 PM
2010 with the air suspension, you're probably bottoming out. My 09 Streetglide was doing the same.
04-30-2018, 08:00 PM
No sir, not bottoming out, jus have to run with lower pressure, I guess, thanks.
04-30-2018, 08:01 PM
Quote:
Originally Posted by
Hades02
Maybe the street glide is a tad different, but not sure.
04-30-2018, 09:15 PM
td61
someone told you wrong. use the chart in your owner's manual as a start point, then adjust up or down to suit your preferences.... i regularly ran with 5 psi in my 2010.
04-30-2018, 10:04 PM
skratch
......use the chart in your owner's manual
05-01-2018, 10:58 AM
Run 30 with the weight mines carrying around. (Yeah, were fat I know)
05-01-2018, 11:19 AM
40 is way too much. When I had stock shocks on mine I ran between 5-10 psi solo.
05-01-2018, 08:20 PM
groupw
k, thanks ☝️🙂
