dynajet fuel comander
RE: dynajet fuel comander
Your dynajet fuel commander is the same thing we would call a chip in a car. You program it to enrichen the fuel and change timining for front and rear cylinders. Harleys run lean out of the factory and tend to run hotter on a lean mixture. When changing pipes and air cleaner your need to richen the air/fuel ratio to the injectors. Thats what the fuel commander does in a nut shell.
HDF Tech
06-29-2005 11:17 AM
