Dielectric Grease
RE: Dielectric Grease
I would only recommend it if you are willing to deal with the absolute mess it will create. The stuff I've used for outdoor wire nuts essentially never dries or even skins over, and is a royal pain in the *** to get off your hands.
There may be varieties out there that don't exhibit this behavior but I don't know of any. I would recommend RTV or other style caulking if you want to create a flexible yet watertight joint in your connector headers.
So even though the ecm connector has a boot, I should use a dielectric grease? How much should I use -- slather it on so it fills the holes or use sparingly -- I'm unclear on this part. Still seems odd to me to be adding a non-conductive material into something I want to conduct VERY WELL.
I *always* use dieletric grease. Sure, it will mess up your hands but it will stop corrosion in its tracks. Last time I had a bulb failure the failure was actually in the socket contacts. A little cleaning, a squirt of grease and problem no more.
It's really cheap insurance.
ORIGINAL: Taterdog
use the dielectric grease sold in a small tube, dab a small dlop on each female connector slot, like very little, dab a little and spread around seal, put the parts together, wipe off excess. Best part of Di grease is it makes it really easy to pull apart the parts later. If you use to much, it will be messy.
