Instrument lights
RE: Instrument lights
I've thought somewhat along those lines but also it seemed strange that the lights were a differant color than the radio. I was going to investigate replacing the lights with led's or see if it could be done... I wanted to change the lights in the guages to a red color to match[sm=bling.gif] the radio.
Looks like the tac and spedo are a sealed unit and you will play hell[sm=badbadbad.gif] in changing them. The bulbs in the guages are hd part # 674450-00 and are a 3.4 wattage rating... They are the ones that you may be able to take and replace with led's but then the guages will be brighter than the spedo and tac... [sm=badidea.gif]
swapped all mine out to red looks incredible www.bluegauges.com did the led on the speedo and tach excellent work
my 01 Eg may be different I pulled one instrument bulb
It looks like 158 but could be 168.
The link should take you to GE lighting, automotive, instrument.
Look up illumens, watt, etc
158 = 25 illumens
168 = 38 illumens
194 = 25 illumens
in this case 168 is brighter
http://genet.gelighting.com/LightPro...amp;model=null
158 = 25 illumens
168 = 38 illumens
194 = 25 illumens
jmeyer58
Electrical/Lighting/Alarm
04-28-2023 03:34 AM
