front turn signal won't flash
You may want to start tracing wiring.
Also, try moving your handlebars from left to right and see if that does anything.
Hook up either a battery tender or charger on your bike (to prevent running your battery down) and turn the turn signal on and start moving/lightly pulling wiring while watching for the light (to hopefully blink) or give you a sign that you located the problem.
Pay attention to connections and ground wires.
Not impossible that you could have a defective module but check the easy, cheap stuff first, including the turn signal switch on the handlebars.
Be patient and good luck.
bout3fitty
06-11-2014 11:46 PM
steelerdude1
03-19-2012 06:16 PM
