Goof Off White Walls
Old 04-25-2018 | 08:51 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Scotch brite pads and SOS pads will get them clean but think about what you're doing to the tire. each swipe puts a tiny microscopic scratch in the rubber which will then collect dirt faster and cause your tire to get dirty sooner.
Old 04-25-2018 | 09:15 AM
SnoRider's Avatar
SnoRider
I used magic erasers for a couple years...then a 2 year stint with no cleaning of the white walls. Then I used Goof Off and they have never been cleaner.
Old 04-25-2018 | 09:17 AM
SnoRider's Avatar
SnoRider
Old 04-25-2018 | 09:21 AM
47Norton's Avatar
47Norton
Little bits of SOS =Little spots of rust! If your going to use this type of scrubber use bronze wool.
Old 04-25-2018 | 10:20 AM
KCFLHRC's Avatar
KCFLHRC
I would be more concerned of the damage it could do to the wheel finish
Old 04-25-2018 | 10:27 AM
perki48's Avatar
perki48
What happened to just going under the sink and grabbing the "Comet"?
Old 04-25-2018 | 10:46 AM
DanRC's Avatar
DanRC
Originally Posted by Keithhu
I'm tellin ya, Magic Eraser is the ****!
Old 04-25-2018 | 11:01 AM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
Goof Off looks like a nice toxic cleaner to use. I've been using this on my Softail Deluxe with great results. They also have the wipes to take on long trips is need be. They're from the Coker Tire folks and make white walls for many of the vintage cars.
The following 2 users liked this post by Ex-Leftcoaster:
H20loo (04-25-2018), SnoRider (04-28-2018)
Old 04-25-2018 | 01:26 PM
DamifIknow's Avatar
DamifIknow
Im pretty sure Goof Off eats rubber but Im sure someone will be along to correct me if im wrong.
From their site:
Is it safe to use Goof Off® Super Glue Remover on rubber?
It can dissolve some rubber materials. Test the product in a small, inconspicuous spot first to ensure no damage occurs.
Old 04-25-2018 | 02:44 PM
stroker87's Avatar
stroker87
Westleys Bleach White but theres a trick to it!
spray the white walls down let it soak in for 5 minutes then spray the one your cleaing again scrub it repeat on the rest
Quick Reply: Goof Off White Walls
