Is this belt alignment right! First Harley Davidson
Hi guys I bought a 2009 Harley Rd., King at the end of last year with 7200 miles on it. Now that the weather is getting warmer I decided to do some oil changes and what not. I noticed that the belt alignment is off to one side the inner part of the pulley. What are your thoughts about this please see pictures. Also does anyone know where The starter Relay is located? Thanks in advance
If it isn't actually rubbing on the pulley flange, it will be ok. If you want perfection then you need some fancy wheel alignment setups and tools. I had that on my 2006 Nightrain and aligned it over and over. Sometimes I got it and sometimes I didn't. I finally opted to put the bike up on a jack and then rotated the wheel while I adjusted the axle adjusters... I didn't worry about perfect middle but I got it away from the flange on the pulley.
