Bike wont start after amp installed
04-11-2018, 09:45 PM
Just installed a RF 4 channel amp and 4 new speakers. Everything buttoned up. Music is playing. Went to start bike, it tries to turn over but wont start. Has anyone experienced this? Any ideas?
04-11-2018, 09:54 PM
Sounds like a drained battery, what is battery voltage reading? Do you have a tender you can plug it into for a few hours?
04-11-2018, 10:17 PM
Quote:
^^^^^That^^^^^
04-11-2018, 10:23 PM
Make sure all the plugins are plugged in the dash or under seat or whatever you had apart go revisit. Check fuses.
04-13-2018, 01:19 AM
Did you make sure to fully recouple the fuel disconnect on the bottom of your tank?
04-13-2018, 03:01 AM
Bafflingbs
Good thought!
04-13-2018, 03:07 AM
I am assuming that it is turning over but no start. Did you fully follow the procedure in the FSM. or did you do it like I do and just pop off the quick disconnect?
04-13-2018, 04:47 PM
Yep happened to me. I had forgotten to reconnect the gas tank fuel plug on bottom of tank. Thought I’d messed up something bad. Check that.
HEROJB
09-08-2018 10:14 PM
remerson
Audio Systems
03-27-2014 11:05 AM
timmanis2000
05-19-2011 04:36 PM
bgismo20
05-05-2008 07:10 PM
bgismo20
05-05-2008 09:29 AM
