Different lengths of shocks after modification
Old 04-12-2018, 02:25 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 4,217 Likes on 2,309 Posts
Originally Posted by serioussv3n
But you not rebuilt with the same kit like mine?
No, I did not. I guess what I'm saying is, because of how complicated your system is to install, it would be easy to make mistakes with the assembly. I know I would probably screw something up if I installed your kit. Harley's instruction sometimes leave a lot to be desired.
Old 04-12-2018, 03:13 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,313 Likes on 1,861 Posts
2-3 Inches? OK then...
Did you Correctly install the "Top Out" (rebound) spring on damper tube and then slide it down inside the Fork tube (see 2 pics below)
OR Did you Incorrectly put the Damper Tube beneath (outside) the Fork Tube (NO pic shown)
Old 04-12-2018, 03:27 PM
serioussv3n's Avatar
serioussv3n
serioussv3n is offline
Yes i did it
and i filled it with oil and pumped the fork to get the air out of system. After that i filled the fork with the correct oil volume. Put the spring into the fork and closed the fork with the fork bolt.
Old 04-12-2018, 03:38 PM
SSpeeDEMONSS's Avatar
SSpeeDEMONSS
SSpeeDEMONSS is offline
I say take them completely apart and start over.
Garrett
Old 04-12-2018, 03:55 PM
multihdrdr's Avatar
multihdrdr
Now the right shock (without cartridge) is longer than the left shock (with cartridge).
Of course I can compress the longer shock absorber and then push through the axle and assemble everything.
It should Hard to compress the longer (without cartridge) side 2-3 inches... Is it hard?
Try pulling down on the Cartridge-side to match the longer side... Can you do that?
Old 04-12-2018, 04:08 PM
serioussv3n
Yes it’s hard to compress.
The cartridge site is already maximum pulled out.
I already compressed the right side to put in the axle and I already did a test drive.
Its better than the stock forks but I don’t know if it’s normal with the different lengths on this kit.
Old 04-12-2018, 04:16 PM
multihdrdr's Avatar
multihdrdr
Well, I can't imagine it being correct because both sides were basically in their "Top-Out" condition while the bike was lifted in the air and they were 2-3 inches different...you can't have that. Then the "Shorter" cartridge side would be limiting your travel.
Again this is all by using your descriptions as No one has seen your situation in person or in pictures
Old 04-12-2018, 07:59 PM
big- mike's Avatar
big- mike
big- mike is offline
When the slider and tubes are put back together correctly the should be the same length no matter what internals are in then if one is that much longer that the other something is wrong maybe one of the slider bushings not sure but something is wrong
Old 04-13-2018, 04:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Thumbs up
I agree. Once assembled, the two fork legs should look identical, prior to fitting them in the trees.
Old 04-13-2018, 04:56 AM
serioussv3n
I will drive now the next time.
And after few time i will check it again.
Maybe the spring will sag in next time to correct length.
Quick Reply: Different lengths of shocks after modification
